GreenmanX
Apr 06, 2009Aspirant
Time Machine 2tb limit?
Hi! I tested the ReadyNAS Pro equipped with 6tb. We (ad agency) are planning to use it with TimeMachine to backup our desktop macs. I wanted to use the maximum capacity, which is 4607GB, for TM, b...
centauratlas
Apr 12, 2010Tutor
Hi,
I'm considering turning on Time Machine support in the ReadyNAS, setting it to the maximum size it allows (4085 GB), creating a sparsebundle image larger than that with htutil and then copying it over to the ReadyNAS.
I know that sparsebundle images can be created with htutil well above the TB range, into the peta and exa-byte ranges (http://developer.apple.com/mac/library/ ... til.1.html) so it is not an issue with sparsebundles. Likewise, I know that TimeMachine can backup to volumes larger than 4TB (e.g. 8 bay Drobo with 2 TB drives works fine).
So, this is again an issue with the ReadyNAS Pro.
Anyone see any issues with creating a backup this way or have a better solution?
e.g. should I just turn off the ReadyNAS support, create the sparse bundle there and use it that way?
Thanks for any insight.
