GreenmanX
Apr 06, 2009Aspirant
Time Machine 2tb limit?
Hi! I tested the ReadyNAS Pro equipped with 6tb. We (ad agency) are planning to use it with TimeMachine to backup our desktop macs. I wanted to use the maximum capacity, which is 4607GB, for TM, b...
centauratlas
Apr 12, 2010Tutor
Well, replacing the ReadyNAS Pro time machine files with a new sparsebundle that was larger didn't help. Still limited to 4.38TB on the ReadyNAS Pro. I am not sure what the issue is with the ReadyNAS Pro and Time Machine with large backups, but it certainly hasn't been living up to its billings since it was released.
Any suggestions on just using a sparsebundle on the ReadyNAS and NOT using the built-in support for TimeMachine?
I am not sure if that would work or not, but am looking for a solution... ;-)
