GreenmanX
Apr 06, 2009Aspirant
Time Machine 2tb limit?
Hi! I tested the ReadyNAS Pro equipped with 6tb. We (ad agency) are planning to use it with TimeMachine to backup our desktop macs. I wanted to use the maximum capacity, which is 4607GB, for TM, b...
sphardy1
Apr 12, 2010Apprentice
Check out: http://www.readynas.com/?p=253
I have 3 mac's all running this way with custom-sized sparsebundles and custom permissions. Not over 2 or 4TB, but I have read of at least one user successfully doing just that by this same method.
Note: If you're using Snow Leopard, take care regarding the sparsebundle naming convention as it appears to have changed (no ethernet address in the name)
