GreenmanX
Apr 06, 2009Aspirant
Time Machine 2tb limit?
Hi! I tested the ReadyNAS Pro equipped with 6tb. We (ad agency) are planning to use it with TimeMachine to backup our desktop macs. I wanted to use the maximum capacity, which is 4607GB, for TM, b...
mdgm-ntgr
Apr 13, 2010NETGEAR Employee Retired
sphardy wrote:
As a test I pointed one of my machines (10.6.2) to a new share and kicked off a TM backup. In the past this would fail as TM cannot make the sparsebundle, but interestingly under the 4.1.7 beta firmware the sparsebundle was created just fine. (note I'm using an NV+, not a pro)
TM can make the sparsebundle fine under Leopard on 4.1.6. RAIDiator 4.1.7 for Sparc and RAIDiator 4.2.10 for x86 include Netatalk 2.0.5. This includes Snow Leopard Time Machine Support along with a range of other AFP fixes.
