GreenmanX
Apr 06, 2009Aspirant
Time Machine 2tb limit?
Hi! I tested the ReadyNAS Pro equipped with 6tb. We (ad agency) are planning to use it with TimeMachine to backup our desktop macs. I wanted to use the maximum capacity, which is 4607GB, for TM, b...
Snuffyspaw_aol_
Nov 22, 2011Aspirant
Thanks for your prompt response.
The board in the ReadyNAS unit has a file size limitation and an unrelated hard drive size limitation.
How does the TimeMachine limitation fit into this? Is it the same as the file size limitation of the board? Or is it a third separate issue?
