janpeter1
Mar 30, 2020Luminary
Time machine backup extremely slow
I have used ReadyNAS 314 for Time Machine backup for our Apple computers for about 5 years and worked well. For about half a year or maybe longer, the Time Machine backup became very, very slow. It t...
- Apr 02, 2020
Hi
The key is really to switch from AFP to SMB. What I understand you need to do that both for the Time Machine setup menu at the NAS and also at setting/access for the Home Folder where the Time Machine backup is located. Do not forget to re-start the computer after this!
After reading the following article I thought it was best to delete the old Time Machine backup and start a new one.
I really think Netgear should update their manual and instructions with these details.
By the way I had some initial contact with Netgear support at level-2 but not very fruitful and indicates lack of documentation on the subject.
Marc_V
Apr 02, 2020NETGEAR Employee Retired
I don't think you need to renew the Time machine backup if you will just switch to SMB. It will only create a new backup if you need to expand the cap.
https://kb.netgear.com/000055135/ReadyNAS-OS-6-9-3-Time-Machine-over-SMB
HTH
Regards
janpeter1
Apr 02, 2020Luminary
Hi
