Rogertheswede
Mar 26, 2012Aspirant
Time machine backup question....
Hello - hope you can help I have two ReadyNAS Duos, both on the latest version. One is primary and the other secondary with backups from one to the other using Rsync over a simple LAN, and all is g...
Rogertheswede
Mar 27, 2012Aspirant
Great thanks - I was clearly over-thining it. The first backup is going to take a while so I'll set it running while I'm away next week.
Thanks for your help!
