rainmakr
Nov 26, 2011Aspirant
Time Machine is painfully slow
I just got a new Ultra 4 (RNDU4220) and am finding Time Machine so slow as to be unusable. I've read various threads here, but am not finding a solution. I'm not well-versed in networks, but if I ...
mdgm-ntgr
Nov 27, 2011NETGEAR Employee Retired
Using Snow Leopard is good. It's the most reliable version of Mac OS X for Time Machine backups at this time. Have you installed the latest 10.6.x update?
Time Machine does backup lots of small system files so performance is going to be a lot lower than transferring large files. Also TMs backups with versioning does have overheads. However your speeds do appear to be terribly slow.
I would try with a diskless model choosing your preferred disks from the HCL
Insert one disk, ensure the NAS is running the latest firmware, then put all disks in and do a factory default (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu)
This will ensure you have a clean setup on the latest firmware.
Then configure Time Machine and see what the backup performance is like.
