JustKJ
Sep 23, 2016Aspirant
Time Machine slow after 6.5.2 update
It may be a coincidence, but I just updated my ReadyNAS to firmware 6.5.2. I back up three Macs to the TimeMachine i have on the unit. The time machines have worked fine since when I purchased it,...
gbeddow
Sep 24, 2016Luminary
What version of the Mac OS are you using?
The reason I ask is I've seen something similar: I, too, upgraded to ReadyNAS 6.5.2 and, when I went to do a Time Machine backup from my MacBook Pro running the latest macOS Sierra 10.12, it took FAR longer than normal to "complete".
But even worse, not only did it NOT actually complete the backup, ALL backups for that MacBook Pro were lost: Even though Time Machine said the most recent backup was the newly completed one, trying to enter Time Machine displayed "Can't connect to a current Time Machine backup". The only option at that point was, from ReadyNAS, to delete and recreate the Time Machine backup share, then start a new backup, losing all backup history. The latter backup is still underway as I write this, but seems to be making reasonable progress; hopefully it'll be solid when it's done.
HOWEVER, on 2 other Macintosh laptops on this same network, both running the previous OS X El Capitan, new, incremental Time Machine backups continue to work just fine to the same ReadyNAS 6.5.2.
Granted, my sample size is small but, in my case at least, it looks like Apple made changes to AFP or other elements of Time Machine backups in macOS Sierra that, in combination with the way ReadyNAS works, require you to start over, losing your backup history. :(
mdgm-ntgr
Sep 24, 2016NETGEAR Employee Retired
Which services are you running under System > Settings > Services?
Which apps do you have installed?
Which ReadyNAS model is this with?
I think it's a good idea to do a fresh full backup after the annual major OSX update anyway and that's what I normally do.
- JustKJSep 24, 2016Aspirant
SMB, AFP, NFS, ReadyDLNA, Rsync, UPnp HTTP HTTPS, Antivirus
Which apps do you have installed?Anti-VIrus Plux
ReadyNAS 314
I think it's a good idea to do a fresh full backup after the annual major OSX update anyway and that's what I normally do.I have not updated past El Capitan latest version 10.11.6
- mdgm-ntgrSep 25, 2016NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- JustKJSep 25, 2016Aspirant
The logs have been sent. I will also add to this as it may be a second symptom, that my itunes library is on a volumne, and i ran into problems playing music yesterday, the song kept pausing and then resuming every 5-10 seconds.
