mikebainbridge1
Jan 31, 2018Aspirant
Time Machine Slow in 6.9.2
Hi All - Brand spanking new 426 - Currently 3 WD Red 4Tb disks in while I get myself configured. I installed 6.9.2 first thing out of the box last night and left it partitioning overnight. First th...
- Feb 12, 2018
ReadyNAS 426 - 6.9.3-RC1 - Just to report that MacOs 10.13 machines seem to work fine with SMB as does my old 10.12 machine. I could not get the 10.13 machines to back up faster than <10Gb a day on AFP when I was on 6.9.2
mdgm-ntgr
Feb 01, 2018NETGEAR Employee Retired
What other services are you running?
Are you running any apps?
Which version of Mac OS X is on your Mac?
- mikebainbridge1Feb 01, 2018Aspirant
Hi
No apps at all
Services: SMB / AFP / Ready DLNA / UnPnP /Http(s) /
MacOS is 10.13.3 on both machines
- mdgm-ntgrFeb 01, 2018NETGEAR Employee Retired
You could perhaps update to ReadyNASOS 6.9.3-T223 (Beta 2), configure the ReadyNAS to use SMB for Time Machine and see if that is any quicker.
Interesting thought - the other think I might try is to fire up an old 10.12 machine and see what that does first. I've had a look at the Beta and the 426 is not specifically mentioned in the i386 section. Did they forget it ?
