sevilabear
Sep 17, 2013Aspirant
Time Machine using OSX Mavericks
Update: Please check you are running new enough firmware first: http://www.readynas.com/forum/viewtopic.php?p=409701#p409701 Hello there, I have a Macbook Air running OSX 10.8 (Mountain Lion) ba...
flamesong1
Oct 26, 2013Aspirant
danpalmer wrote: I'm new to this forum, so sorry if I'm asking a question with an obvious answer, but where is the beta for the ReadyNAS NV+ v2? I'm having exactly the same issue on Mavericks with mine and there doesn't appear to be a software update or workaround yet.
If you look at the main forum page:
You will see a section at the bottom called READY NAS BETA (I put it in all caps because that's how it is on the page) and there is a link to:
Public RAIDiator Beta for ReadyNAS NV+ v2/Duo v2:
viewforum.php?f=148
