sevilabear
Sep 17, 2013Aspirant
Time Machine using OSX Mavericks
Update: Please check you are running new enough firmware first: http://www.readynas.com/forum/viewtopic.php?p=409701#p409701 Hello there, I have a Macbook Air running OSX 10.8 (Mountain Lion) ba...
danpalmer
Oct 26, 2013Aspirant
flamesong wrote:
If you look at the main forum page:
You will see a section at the bottom called READY NAS BETA (I put it in all caps because that's how it is on the page) and there is a link to:
Public RAIDiator Beta for ReadyNAS NV+ v2/Duo v2:
http://www.readynas.com/forum/viewforum.php?f=148
Thanks for the help. I had found that bit already, but there doesn't appear to be a recent beta, and nothing that suggests a fix for this Time Machine bug. RAIDiator 4.x and 6.x appear to have received an update to address it, so I assume there must be one for 5.x?
