sevilabear
Sep 17, 2013Aspirant
Time Machine using OSX Mavericks
Update: Please check you are running new enough firmware first: http://www.readynas.com/forum/viewtopic.php?p=409701#p409701 Hello there, I have a Macbook Air running OSX 10.8 (Mountain Lion) ba...
rssnape
Nov 02, 2013Aspirant
I received the following error after updating to RAIDiator 5.3.10-T3, when trying to access the time machine settings in Dashboard.
7061010006
Code: 7061010006
As a follow up: after the install it would not complete booting and it would not respond to the power button, It said booting.... installing add-on. Had to unplug and force a restart. After a successful reboot I had the above error. I also could not access my previous shares.
I down graded to 5.3.9 as I thought my problem was with the beta. Had the same boot problems and still can not access my shares. below is the log from the NAS
Mon Nov 4 05:46:28 EST 2013 System is up.
Mon Nov 4 05:46:25 EST 2013 The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume.
media
Scotts_Data
backup
Kirstens_Data
Mon Nov 4 05:45:31 EST 2013 Your ReadyNAS device has been updated with a new firmware image. (5.3.9)
Mon Nov 4 05:45:24 EST 2013 Volume scan failed to run properly.
Sun Nov 3 06:26:25 EST 2013 314: ERROR: mysql failed while loading RNP2DB-V25.sql.
Sun Nov 3 06:26:12 EST 2013 Volume scan failed to run properly.
Sat Nov 2 21:14:08 EDT 2013 System is up.
Sat Nov 2 21:14:06 EDT 2013 The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume.
media
Scotts_Data
backup
Kirstens_Data
Sat Nov 2 21:13:19 EDT 2013 Volume scan failed to run properly.
Sat Nov 2 19:54:28 EDT 2013 Detected increasing uncorrectable errors[865] on disk 3 [WDC WD20EARX-00PASB0, WD-WCAZA8334391]. This often indicates an impending failure. Please be prepared to replace this disk to maintain data redundancy.
Sat Nov 2 19:50:42 EDT 2013 Reallocated sector count has increased in the last day.
Any help would be appreciated. How can I get the unit to do a volume scan now that it is up?
7061010006
Code: 7061010006
media
Scotts_Data
backup
Kirstens_Data
media
Scotts_Data
backup
Kirstens_Data
