sevilabear
Sep 17, 2013Aspirant
Time Machine using OSX Mavericks
Update: Please check you are running new enough firmware first: http://www.readynas.com/forum/viewtopic.php?p=409701#p409701 Hello there, I have a Macbook Air running OSX 10.8 (Mountain Lion) ba...
Skywalker
Nov 04, 2013NETGEAR Expert
vrspectre wrote: I only have it once under AFP. i attached a screenshot of the bonjour browser that shows where else it's show up as well.
So the _adisk record (for TimeMachine) isn't even showing up. Can you make sure you have TimeMachine support enabled? If so, maybe try disabling it and then re-enabling it.
