sevilabear
Sep 17, 2013Aspirant
Time Machine using OSX Mavericks
Update: Please check you are running new enough firmware first: http://www.readynas.com/forum/viewtopic.php?p=409701#p409701 Hello there, I have a Macbook Air running OSX 10.8 (Mountain Lion) ba...
mrzzy
Nov 04, 2013Aspirant
Skywalker wrote:
So the _adisk record (for TimeMachine) isn't even showing up. Can you make sure you have TimeMachine support enabled? If so, maybe try disabling it and then re-enabling it.
Ahhhhh... Thanks for this suggestion. I had installed 4.1.13 RC1 and my Mac Mini running Mavericks still couldn't find my Duo Time Machine. After disabling Time Machine support in Frontview and re-enabling it, the mac found the ReadyNAS. Now it is happily backing up to the ReadyNAS Duo.
BTW, thank you, thank you, thank you for continuing to support the Sparc-based Duo. I just upgraded it to a pair of 2TB WD Red disks and I expect to keep using it for a long time. It's still doing a great job.
