sevilabear
Sep 17, 2013Aspirant
Time Machine using OSX Mavericks
Update: Please check you are running new enough firmware first: http://www.readynas.com/forum/viewtopic.php?p=409701#p409701 Hello there, I have a Macbook Air running OSX 10.8 (Mountain Lion) ba...
vrspectre
Nov 06, 2013Apprentice
Skywalker wrote:
So the _adisk record (for TimeMachine) isn't even showing up. Can you make sure you have TimeMachine support enabled? If so, maybe try disabling it and then re-enabling it.
Brilliant that worked for me. It let me use the disk and enter my credentials. It's preparing the backup now. I'll post again if I run into any other trouble.
I could have sworn I had done that but apparently not. Maybe I did, but just didn't hit the apply button. Who knows.
One last note, any reason it's showing 2.57 TB available? I set my allocation to 2000GB so it shouldn't be able to use more than that. Plus I thought Time Machine had a limit in it of 2TB.
