sevilabear
Sep 17, 2013Aspirant
Time Machine using OSX Mavericks
Update: Please check you are running new enough firmware first: http://www.readynas.com/forum/viewtopic.php?p=409701#p409701 Hello there, I have a Macbook Air running OSX 10.8 (Mountain Lion) ba...
blac
Dec 26, 2013Aspirant
I installed 5.3.10-T3 on my Duo v2 and have a complete Time Machine backup.
I had an issue with my iMac hard disk, so reformatted and reinstalled Mavericks.
When I try to transfer information from the back up, I login and I see the machines I have backed up, but the message "No volumes found in backup" appears under 3 of 4 machines.
There is a pop up message the first time I try:
I have turned off Time Machine on the other computers, but that doesn't help.
I've connected with my MacBook via AFP and see that the sparse images are all there, but don't know how to access the backup from the Time Machine restore.
Any ideas?
Thanks
Some backups cannot be opened.
Make sure that all of your network devices are
connected and turned on. It appears that some
backups are already in use. If you don't see the
backup you need, make sure it is not currently
mounted by another machine and try again.
Any ideas?
Thanks
