sevilabear
Sep 17, 2013Aspirant
Time Machine using OSX Mavericks
Update: Please check you are running new enough firmware first: http://www.readynas.com/forum/viewtopic.php?p=409701#p409701 Hello there, I have a Macbook Air running OSX 10.8 (Mountain Lion) ba...
simps100
Dec 31, 2013Aspirant
Having a problem with OSx Mavericks and a Readynas Duo V2 running RAIDiator 5.3.8
The device is discovered when browsing under Time Machine settings, I'm able to select it and hit connect but then i get the error: "The server may not exist or it is unavailable at this time. Check the server name or IP address, check your network connection, and then try again." - I don't even get the username / password prompt.
Have checked for updates for the ReadyNaS and it seems to be up to date- any other ideas?
