sevilabear
Sep 17, 2013Aspirant
Time Machine using OSX Mavericks
Update: Please check you are running new enough firmware first: http://www.readynas.com/forum/viewtopic.php?p=409701#p409701 Hello there, I have a Macbook Air running OSX 10.8 (Mountain Lion) ba...
RTRDigital
Jun 26, 2014Aspirant
Has anyone found a fix for this. I can get the backup to work for two days if I reset the share access but it continues to eventually run into this problem. If you are still having this problem there is a temp fix. Go into OS6 and disable time machine and re-enable it. Go through and setup time machine again and it will work for a bit as long as the Mac is plugged in and on Wi-Fi.
