Denis1
Oct 03, 2019Tutor
Time Machine
I got a ReadyNas Pro with frimware 6.10.1; my timemachine was setup with an old Firmware. Was working with no problems at all. Today my older IMac hadn't done it's backup. I tried to see if Timemachi...
Oct 04, 2019Guru - Experienced User
Did you try rebooting
Denis1
Oct 04, 2019Tutor
It's not a windows machine, but yes. I rebooted. Same error.
I looked into a private Time machine. Because of the message it shouldn't work. Well, it did work. Which means theres a bug somewhere. Someone should look into it.
- Denis1Oct 04, 2019Tutor
And this isn't a solution, it's a work around.
- StephenBOct 04, 2019Guru - Experienced User
... And this isn't a solution, it's a work around.
Agreed, it would be a workaround. I never suggested it was a windows machine - FWIW, I was meaning to ask if you'd tried rebooting the NAS.
You could use paid support for this - that would start troubleshooting. Or send a PM to one of the mods ( JohnCM_S or Marc_V ) and ask them if Netgear wants to access your system remotely and take a look.
- Denis1Oct 22, 2019Tutor
Marc I thought I sent it. Well one more try
I figured something out tonight. Finally took the proper time and looked at why time machine wasn't working. This is what I found out.
- Someone on netgear changed the shared Time Machine to local user only. Why do I know that because I was able to make the share in the past and I'm using active Directory. How do I know it only works with local users, I looked at the ? mark and it says only local users. Incredible, who asked for this? Should it be the adim who decides? Or was it alwas local and it never checked?
- Readynas says apple now uses SMB, no need to use AFP. One problem, it seems time machine still use AFP! I saw this on the Apple community. Very confusing if you ask me, some say it work with SMB and some say iy only works with AFP. Turned back AFP with a dedicated Time Machine share and there she is!!!
The moral of the story is upgrading MAC OS 10.6 to 10.11, don't trust what it should use. The thing that got me is Netgear changing how the shares work or again they never forced the local users only.
StephenB I was just joking about the reboot. Everyone says that because of Windows and now we all reboot everythng because of windows because it does work for windows; why not the rest.
