coolhandmatt
Nov 17, 2013Aspirant
Time To Talk ReadyNas Duo Help
I'm not network expert! I own a readyNAS Duo, and I have a problem. Description- 1. A few weeks ago readyNAS sent me an email indicating: Number of bad sectors on disk 2 is growing. 2. Upon revi...
Nov 23, 2013Guru - Experienced User
You haven't yet told us if you have a duo v1 or a duo v2.
If you reinserted disk 1 with the NAS running, then if should be using the factory default password (either netgear1 or password, depending on your model). All data would be gone.
