rawb1
Feb 27, 2016Aspirant
Timemachine and dual Ethernet interfaces
OS version 6.4.2, OS X 10.11.3 (El Cap). This ReadyNAS has two ethernet interfaces, which I had connected unbonded to the network. All of the Macs on the network would attach and update the s...
- Feb 28, 2016
Hi rawb1,
With regard to using multiple NICs or ethernet adapters in your ReadyNAS system, here are some helpful NETGEAR articles you can look at.
ReadyNAS OS 6: Configure Bonded Adapters
ReadyNAS - What bonding/teaming mode should I use?
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
mdgm-ntgr
Feb 27, 2016NETGEAR Employee Retired
Having two NICs with different I.P.s in the same address range is not recommeneded. There are teaming methods you can use that don't require a switch that supports and is configured to use 802.3ad LACP which you could possibly use till you get a switch that supports 802.3ad LACP. Or you could run on just the one NIC as you found worked for you.
