rawb1
Feb 27, 2016Aspirant
Timemachine and dual Ethernet interfaces
OS version 6.4.2, OS X 10.11.3 (El Cap). This ReadyNAS has two ethernet interfaces, which I had connected unbonded to the network. All of the Macs on the network would attach and update the s...
- Feb 28, 2016
Hi rawb1,
With regard to using multiple NICs or ethernet adapters in your ReadyNAS system, here are some helpful NETGEAR articles you can look at.
ReadyNAS OS 6: Configure Bonded Adapters
ReadyNAS - What bonding/teaming mode should I use?
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
Feb 28, 2016NETGEAR Employee Retired
Hi rawb1,
Hope this helps!
Kind regards,
BrianL
Feb 28, 2016Guru - Experienced User
My main recommendation is to leave teaming off, unless you often have multiple simultaneous users. Teaming doesn't improve single-user speeds.
If you have enough users to benefit from it, and don't have switch support for LACP, then try ALB.
