vtxrider
Oct 19, 2015Tutor
Timemachine not found in IOS 10.11 (El Capitan)
Ever since updating to IOS 10.11 the ReadyNAS disk no longer mounts, and Timemaching cannot find the disk. I have tried turning the option off/rebooting/re-enable option sequence but it still will no...
- Oct 26, 2015
It seems it was a permissions issue, the new OS X ver 10.11 has done away with the permissions repair option in disk manager, not sure why. I did try to toggle it off in time machine but as the disk is not found it was not displayed as an available disk. Cold Rebooting the NV2+ with the Mac on fixed the issue as the NAS is now showing up in finder again under shared devices. Not sure why it lost permissions after the upgrade, and I didn't think to reboot the NAS right away as it was working fine with my iPhone and media streamer.
BrianL2
Oct 19, 2015NETGEAR Employee Retired
Hi vtxrider,
Try to toggle on/off the Time Machine in your MAC as well as the Time Machine service of the ReadyNAS. You may also want to change the Time Machine credential on your ReadNAS to another one. Can you also tell us what is the model of your ReadyNAS and its Firmware version?
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
vtxrider
Oct 26, 2015Tutor
- BrianL2Oct 27, 2015NETGEAR Employee Retired
Hi vtxrider,
Thank you for sharing the fix that you've made in your MAC computer and ReadyNAS in order for Time Machine backup to work again. It would be a best practice to reboot your MAC, PC and ReadyNAS after a software or a firmware update.
Let me know if you have other questions.
Kind regards,
BrianL
