HansK
Jan 23, 2021Apprentice
Timemachine on RN104
i can't seem to enable timemachine on RN104. See enclodes screenshot. This is something like NAS does not support timemachine. On the RN104 I enabled private timeshare account. also enabled ...
JohnCM_S
Jan 27, 2021NETGEAR Employee Retired
Hi HansK,
May I know the current firmware version of your RN104? May I also know the version of the MacOS?
You may also download the system log of the RN104 and then provide it to us. We will check if we can find something there that could be the cause of the issue. You may upload it to a cloud storage site then send the download link via private message.
- HansKJan 28, 2021Apprentice
Hi,
Thanks for reaching out te me.
the firmware version for the RN104 is 6.10.4
The Mac OS is macOS Big Sur version 11.1
I attached the system log dating back from 1-1-2020 until now. You should be able to access these files via a one drive link.
<redacted>
best regards,
Hans
- StephenBJan 28, 2021Guru - Experienced User
The log zip file shouldn't be posted publicly. JohnCM_S requested that you send the link via private message. You do that using the envelope link in the upper right of the forum page.
I'll redact your link, and forward it to JohnCM_S.
- HansKJan 28, 2021ApprenticeThanks I removed the original link and sent a new one via PM
