glashoppah
Apr 10, 2012Aspirant
TimeMachine sparsebundle corruption fix
Dear Colleagues,
Ever since upgrading my Mac to Lion I have had a curious problem which I've been working (for months) with Apple. Basically once every week or two, always on a Monday morning, the TM process would report that it could no longer read the backup due to corruption and would need to create a new one. This is the infamous "TimeMachine completed a verification" error. It would then delete the old backup set and start over.
This really drove me nuts. Clearly a change in Lion had caused this to begin, but I couldn't figure out why it was so predictably periodic. I never had a problem with TM under Snow Leopard, which ran for me just fine for well over a year.
Anyway, a few weeks ago when I was scratching my head for the 100th time on this problem I noted that the ReadyNAS was running its weekly RAID scrub during the time period in which TM was failing. Basically I kick off the RAID scrub at 04:00 AM and it usually runs until about 10:00 AM or so. The TM process would fail at between 08:00 and 09:00 AM during this scrub.
Clearly - to me - Lion is failing to verify its writes as assiduously as Leopard did, and the interaction between the very busy READYNAS and TM with Lion's filesystem was causing this corruption. I was now confronted with a new problem - TM's schedule is not configurable. It backs up every few minutes. So there was no way for me to "window" it to have it avoid the RAID scrubbing time.
Then a few Web searches later I found "TimeMachineEditor". This freeware utility lets you create complex schedules for TM. Perfect! I was able to not only have TM *not* back up during the RAID scrub, I was also able to set TM to back up once an hour rather than every few minutes, which is a lot more usable for me. This has fixed the problem.
So if you're having weird problems with TM backups getting corrupted and you can see that it's happening during your RAID scrub, try "TimeMachineEditor."
Sincerely,
H.
Sincerely,
H.
- G_man1AspirantI have just converted from PC to Mac and I think I have run into this problem.
I setup time machine and all was well until my Mac went to sleep in the middle of a back up. Since then my Mac mini will not connect to my Nas for back up. I have tried resetting everything and still will not connect. Unfortunately I'm not good with command line.
Could somebody please tell me in lay terms what has gone wrong and if the issue on this tread might be what I'm experiancing?
Thanks
