themastah
Mar 01, 2020Tutor
Timing out when connecting to ReadyNas 102
I've got a ReadyNAS 102. Yesterday I went in and added the Plex app to use with my Roku TV. I found that I could see the different films but they wouldn't play, so I decided to go back in to the admi...
themastah
Mar 01, 2020Tutor
Update 2 - from ReadyCloud, the PC was trying to connect to http://192.168.1.2 but the Mac opened http://192.168.1.9. Putting that URL into the PC manually works just fine.
So, how come ReadyCloud doesn't know where to really look for the ReadyNAS in order to manage it? Pretty confusing to me!
Mar 02, 2020Guru - Experienced User
ReadyCloud likely was using an old IP address.
I suggest reserving the NAS IP address in your router, so it won't change when you reboot the NAS (or when you reboot the router).
- themastahMar 02, 2020Tutor
Thank you, I've set that up on the router. Good suggestion.
