artkaos
Apr 29, 2016Aspirant
tips to increase traffic (bonding)
Hello, I'am french, sorry for my english. I dont find help on french support. I have a RN104 and actualy i choose LACP on my RN104 and my switch. i'ts work but i dont win more speed. Why ? ...
- Apr 29, 2016
Bonding doesn't double your speed. Each traffic flow through the bond is still limited to 1 gigabit. The reason is that the link between the switch and the client is limited to 1 gigabit anyway, so it really can't go any faster.
Bonding can improve performance if you have multiple clients trying to use the NAS simultaneously (each client is limited to 1 gbit, but the total traffic to all clients can reach 2 gigabits).
But the RN104 really isn't fast enough to reach one gigabit speeds. So even though it supports bonding, it can't take advantage of the extra bandwidth.
artkaos
Damned :mansad:
Thanks for your help,
I thought to increase bandwidth whith bonding, actualy, i have 30 or 45/MB/s.
I bought a switch for nothing :)
Apr 29, 2016Guru - Experienced User
Though it is painful, you probably could increase the throughput if you did a factory reset (rebuilding the NAS and restoring all the data from backup). I did that a couple months ago with my RN102, and saw a marked increase in speeds (around 70 MB/s if I remember correctly). Though I use jbod, not xraid.
If you want to try that, perhaps wait for 6.5 to be released.
- artkaosApr 29, 2016Aspirant
Does the upgrade to 6.5 erase all my datas ?
