davidpw
Oct 23, 2010Aspirant
Tivo not archiving - ReadyNAS Pro 4.2.15
(moved post from Streaming Services forum) I have enabled Tivo support. There are shows that have been set as Keep Until I Delete (KUID). I have confirmed this using the Tivo itself and Tivo Deskto...
davidpw
Oct 24, 2010Aspirant
(update)
also tried removing all KUID flags, turned off Tivo support then turned it on again and reregistered the Tivo.
Reset all the KUIDs.
no change in the problem. Its as though the ReadyNAS thinks it WAS a KUID, rather than IS a KUID.
David
David
