davidpw
Oct 23, 2010Aspirant
Tivo not archiving - ReadyNAS Pro 4.2.15
(moved post from Streaming Services forum) I have enabled Tivo support. There are shows that have been set as Keep Until I Delete (KUID). I have confirmed this using the Tivo itself and Tivo Deskto...
davidpw
Nov 04, 2010Aspirant
thanks for the info.
I suspect that it is a database problem. Although no DB errors appear in the log, the last time it worked I received this message (just after I upgraded to 4.2.15):
[2010/10/21 22:49:39] main.c:156: info: Starting ReadyTiVo 1.3.3...
[2010/10/21 22:49:39] main.c:190: warn: Updated DB schema to version 1
From then on I receive:
[2010/10/21 22:49:47] discovery.c:105: info: Verifying newly found TiVo (DVR-E9E5)...
[2010/10/21 22:49:47] discovery.c:121: info: DVR-E9E5 is authorized
[2010/10/22 01:00:01] main.c:236: info: Doing TiVo downloads...
[2010/10/22 01:00:02] config.c:210: info: Next archival scheduled for: Sat Oct 23 01:00:00 2010
[2010/10/22 01:00:24] tivo_utils.c:246: info: The Music Instinct: Science & Song ((null)) is no longer KUID. Skipping.
[2010/10/22 01:00:25] tivo_utils.c:246: info: Monster Moves (Risky Rescues) is no longer KUID. Skipping.
etc for each of the shows that are KUID.
David
David
