davidpw
Oct 23, 2010Aspirant
Tivo not archiving - ReadyNAS Pro 4.2.15
(moved post from Streaming Services forum) I have enabled Tivo support. There are shows that have been set as Keep Until I Delete (KUID). I have confirmed this using the Tivo itself and Tivo Deskto...
davidpw
Nov 05, 2010Aspirant
Tried the technique and, sure enough all the database entries were deleted (now get a blank dump.txt).
However this did not fix the problem.
The ReadyNAS scans the Tivo and for every file that is KUID I get the message that it is not KUID. Seems like half the code knows that it is KUID but not the other half.
Cannot think of anything further to try, I wonder if it has something to do with Australian versions of the Tivo confusing the ReadyNAS?
David
David
