davidpw
Oct 23, 2010Aspirant
Tivo not archiving - ReadyNAS Pro 4.2.15
(moved post from Streaming Services forum) I have enabled Tivo support. There are shows that have been set as Keep Until I Delete (KUID). I have confirmed this using the Tivo itself and Tivo Deskto...
saa1
Nov 05, 2010Aspirant
aeimis wrote: saa: your log shows an sql error missing a field named source_tivo. Here are the my downloaded headers from the file export.csv.
#SHOW_TITLE EPISODE_NO EPISODE_TITLE SOURCE_TIVO DURATION SERIES_ID PROGRAM_ID RECORDED_TIME ARCHIVAL_TIME
your db could be just missing the field or more likely there is some other things missing which may require a reinstall....
Thanks aeimis! It looks like I may have a problem with the TiVo database. I've searched the boards looking for something similar or a description of how to reset/rebuild the database, to no avail. Does anyone know of a way to do this? Alternatively, can I upgrade the ReadyDLNA service? I don't see a button to remove it. It reports version v1.0.18.2.
Thanks!
Scott
