davidpw
Oct 23, 2010Aspirant
Tivo not archiving - ReadyNAS Pro 4.2.15
(moved post from Streaming Services forum) I have enabled Tivo support. There are shows that have been set as Keep Until I Delete (KUID). I have confirmed this using the Tivo itself and Tivo Deskto...
aeimis
Nov 06, 2010Aspirant
saa, As a suggestion If contacting readynas support does not yield you the current readytivo addon to reinstall, I would just reapply the 4.2.15 update bin file and see if everything is fixed. Backup the data on the unit, of course. I also found some other versions but I after reviewing my logs the current version on my unit is ReadyTiVo 1.3.3 and I can't find it posted. The others are for your reference. Good luck.
http://www.readynas.com/download/RAIDiator-x86/RAIDiator-x86-4.2.15
http://www.readynas.com/download/addons/x86/4.2/ReadyTiVo_1.1d-x86.bin
http://www.readynas.com/download/addons/x86/4.2/ReadyTiVo_1.3.1-x86.bin
http://www.readynas.com/download/addons/x86/4.2/ReadyTiVo_1.3.2-x86.bin
