Alex_CCIM
Feb 15, 2017Apprentice
Tools Errors on RN202
Hello, I am experience some strange errors. I did a factory default with my RN202 and two 3TB drives. I set it up at RAID0. I backed-up some 2.6TB of data from another ReadyNAS that I having ...
- Feb 21, 2017
FramerV,,
i appreciate the follow-up. I followed the directions you provided and email my logs to the address in the instructions. I never heard from that action. I did get a response from the error message sent from my unit to Netgear:
To: ReadyCloud <[email protected]>
Subject: Customer Error ReportModel: ReadyNAS 202
Firmware: 6.6.1
Context: system_panel_storage
Error: 14007010000
Defrag Volume Command failedSomeone from Netgear engineering sent me a hotfix. I installed it and the problems were fixed.
Alex
FramerV
Feb 17, 2017NETGEAR Employee Retired
Hi Alex_CCIM,
You might want to double check if there are other messages on your logs. You can also send us the logs.
How do I send all logs to ReadyNAS Community moderators?
FramerV
Feb 21, 2017NETGEAR Employee Retired
Hi Alex_CCIM,
Just would like to verify if you were able to sort this case out.
- Alex_CCIMFeb 21, 2017Apprentice
FramerV,,
Firmware: 6.6.1
Error: 14007010000
Alex
- Mar 26, 2017Retired_Member
