Medleyman
Jan 23, 2012Aspirant
Torrents losing connection to server?
Hi all! One of the main reason for me getting an ultra 2 was so I could use the bittorrent add on utility and finally let my PC enter sleep mode. But, when I start the torrents on the ReadyNas...
JarnoG
Jan 24, 2012Guide
What do you mean with "lose connection to the server"?
1) Can they no longer connect to the tracker or
2) Can they no longer connect to seeds/peers?
3) You can no longer connect to the Transmission interface
If it happens to both Transmission and the old bittorrent add-on from Netgear, then it has most likely something to do with your network configuration. What you can try is to turn on the option "use port forwarding from my router" on the network tab in the preference menu in the Transmission WebGUI. That way, you might solve the 2nd problem I mentioned.
