Soody
Oct 12, 2016Aspirant
Toshiba P300 3TB Drive
Hi all, first posting. Had a quick search and looked at the hardware compatibility list but no success. Have an opportunity to connect up a DUO v2 that I have just been given as a back up unit to my ...
Soody
Thanks for the linik re different models. Just checked the back and the layout is that of a v1 even though the label underneath says v2. Nice move Netgear....
Oct 12, 2016Guru - Experienced User
They've paid the price for that mistake many times over...
Unfortunately the v1 is limited to 2 TB drives, so you can't use the Toshiba P300.
The HCL for both the v1 and the v2 is dated, Netgear has stopped updating it. You can use WD20EFRX or the ST2000VN000 NAS-purposed drives are a good fit for your NAS, it isn't fast enough to get any speed boost from enterprise-class drives. Though 2 TB or smaller enterprise drives should work.
- SoodyOct 12, 2016Aspirant
Stephen, thanks for the info. As they say 'Bugger!' I have 12TB in my main PC and wanted to back off a lot of that into the NAS unit. Sounds like I will need to look for an alternative NAS unit as 4TB max won't meet my needs.
Suspect I won't get much for it on eBay.
Regards
Soody
- StephenBOct 12, 2016Guru - Experienced User
An RN214 would be a reasonable choice.
Thanks,
There is a brand new NAS202 on eBay for sub £200 with 2 x 3TB HDs.
