bobpetit's avatar
bobpetit
Connecting a WNDR4500v3 router to a Toshiba FlashAir W-02
Has anyone had success connecting a Toshiba FlashAir SDCARD to this router. My router sees the card and shows it in the list of connected devices but the router will not give it an IP address. It just shows it as "unknown". I've configured the SDCARD correctly which is why the router sees it but something is preventing the IP assignment.
  • It finally started working. I added a few more options to the config file manually and it finally connected.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi bobpetit
    Welcome to the community!
    Try to assign a static IP by using the Address Reservation feature on the router.
    See this article for more information.
    • bobpetit's avatar
      bobpetit
      • ElaineM's avatar
        ElaineM
        Can you share what additional things you have added?
