dima12
Aug 07, 2017Aspirant
Transfer speed with ReadyNas 212
Hi all, my setup is: Router: Netgear D6200 (AC 1200 wifi router) WiFi Adapter: Netgear A6210 (AC 1200 adapter) ReadyNAS 212 with 2x 4TB WD RED Cables: 5E CAT cables The adapter is just 4/5 m...
Aug 08, 2017Guru - Experienced User
Can you measure the speed using a wired ethernet client?
dima12
Aug 08, 2017Aspirant
What do you mean? When wired the speed is around 100 MB/s for big files.
- StephenBAug 08, 2017Guru - Experienced User
dima12 wrote:
What do you mean? When wired the speed is around 100 MB/s for big files.You didn't say in your original post that you'd measured it. Just that you didn't expect that speed on wifi.
If you are getting 100 MB/sec from the NAS, then your issue is really with WiFi. You could repost in the home networking forum. But I think that ~200 mbits per second (27 MB/s) is about right for the D6200. It's consistent with some D6200 router reviews I've seen.
- HopchenAug 08, 2017Prodigy
Hi Luca,
Your router can do 867 Mbit/s theoretically. That will never translate to real life usage. 867 Mbit/s you might be able to reach on the wifi, if you are in outer space - in a vacuum with zero signal loss.
In the real world you will always loose some signal to the environment. The speeds you see on the wifi is just fine for a router like the R6200. No problem there.
Cheers- dima12Aug 08, 2017Aspirant
Thanks for the replies guys.
I just thought that you should achieve at least something around 40 or 50 MB/s with my setup, also considering that the adapter is pretty close to the router, I cannot imagine how much it would degrade if it were on the oppise side of the flat!
What router would you need in order to be reasonably sure to achieve such speeds?
- HopchenAug 09, 2017Prodigy
Hi Luca,
50MB/s (400Mbit/s) is pretty fast on wifi! It is not so easy to get :)
However, Netgear's Nighthawk series of routers can probably do it but remember you probably also need a wireless adapter that is better/faster than the one you have now.
To be honest, these routers will cost you quite a bit of money. Is it really worth it? The speeds you are getting now are very decent.
In the future, I suggest that you look up reviews online before you buy, so that you can see what real-life wifi speeds to expect.
Good luck!
