swehjo
Apr 17, 2014Guide
Transfering 930GB to USB 2,5 days normal?
See question in subject line and my settings in the signature. 2,5days for transferring 930MB directly to the USB-disk via the front contact seems a lot... Or is it as expected?
Apr 18, 2014Guru - Experienced User
If your system is failing, then it is best to get your data off as quickly as possible, and avoid troubleshooting secondary problems.
I would attach your USB drive to a PC, and copy the data over the network. That is faster than USB.
Also, did you mean 930 MB or 930 GB? 930 GB will take multiple days over USB (and will take about a day over a gigabit network). 930 MB on the other hand should be a few minutes, not days.
