garyd9's avatar
garyd9
Virtuoso
Jun 27, 2016
Transplanting drives from RN516 to legacy Pro BE
I know it's unsupported...  I already have backups...
I have a RN516 running 6.5.1.  I also have an old RNDPiForgotTheModelNumber-100 (The old ReadyNAS Pro Business Edition) running 6.5.1.
I'm going to be replacing all the HDD's in the 516 and doing a factory reset on it.  While I'm doing that (and re-building all the shares, etc), I'd like to keep the existing shares active.  If I pull the drives from the 516 and put them in the older ProBE, will it boot up and work?
My gut feeling is that it should work - both are using the exact same firmware (6.5.1), and the same platform (x86_64.)...
Thanks
Gary
  • It works.  No need to reinstall anything.  I did have a bit of network trouble, but that was my own fault for not dropping the ADS connection and NIC teaming modes before switching.
    That does lead to one comment for netgear, in regards to the RN516:  THANK YOU.  Opening up this old ProBE reminded me how much hotter and noisier it is, and how much of a royal PITA those tiny f'ing screws are.
    (The heat I'm referring to is HDD heat.  I can't fairly compare CPU heat as I switched CPU's in the ProBE...)
  • StephenB's avatar
    My gut feeling says it should work also (though perhaps an OS reinstall might be needed).
    If you go for it, let us know the outcome.
    • BrianL2's avatar
      BrianL2
      NETGEAR Employee Retired
      Hi garyd9,
      As long as the Firmware, architecture (processor) are the same, this should work fine. Since the data has been backed up, do this at your own risk.
      Kind regards,
      BrianL
      NETGEAR Community Team
  • It should work. Both are x86.
    In my opinion though, an OS Reinstall is exactly the thing to avoid. I never tried it, but from my understanding OS Reinstall extracts some files from the flash to the OS volume. Both OS being completely different, you might completely kill the OS.
    But HDDs from OS4 x86 into an OS6 x86 chassis works fine, so other way should be ok too ;)
    • garyd9's avatar
      garyd9
      Virtuoso
      they're both x86 running 6.5.1.  OS reinstall should effectively do nothing.  I'll be trying this tonight or tomorrow morning...
    • StephenB's avatar
      When you convert a legacy x86 NAS to OS6, part of the process installs OS 6 on the flash.  So the OS aren't diffferent.
      But I wasn't completely certain if the firmware install/reinstall includes any device-specific drivers - that was why I suggested that an OS reinstall might be needed.  It's useful to confirm it was not.
  • Retired_Member's avatar
    Retired_Member
    if you have installed 6.5.1 on your Pro, then OS Reinstall should not be a problem. But is probably not even necessary
    • BrianL2's avatar
      BrianL2
      Hi garyd9,
      Just update this thread once done :)
      Kind regards,
      BrianL
      • garyd9's avatar
        garyd9
        Virtuoso
ProSupport for Business
