Toyonut
Aug 09, 2016Aspirant
Trimming SSD
Hi We have just put 2 Samsung 850 Evo SSD drives into our RN 4220 as a test. I have read through the support forums and found this thread about trimming SSD: https://community.netgear.com/t5/New-to...
mdgm-ntgr
Aug 10, 2016NETGEAR Employee Retired
You could try that (note that running stuff as root using sudo would be pointless so you could leave that bit out of the commands) at your own risk (just like enabling trim as described in the other thread would be at your own risk).
Our OS is based on Debian. If it will run on Debian then it should run on the ReadyNAS.
