mas99
Feb 03, 2012Aspirant
Trouble shooting slow network speeds on NV
I’ve had slow transfer speeds on my internal network for some time. I’ve upgraded some hardware and run a variety of tests and I still don’t think I’m getting the speeds I should. I’m out of ideas and...
Feb 03, 2012Guru - Experienced User
I suggest that you try a direct connect of the ReadyNas to the XP desktop, and retest the speed. Also look at the network stats and see if those idle errors, etc also occur with direct connect.
I would also measure the desktop to laptop transfer speed over wireless. jperf is a good tool for this. WiFi link speeds are very misleading, they often don't correlate to actual throughput. While you are at it, you might also try a wired test (using the lan port on the laptop and disabling the wifi),
I am puzzled on the router model - it should be something like MI424WR REV. I Can you check?
