mas99
Feb 03, 2012Aspirant
Trouble shooting slow network speeds on NV
I’ve had slow transfer speeds on my internal network for some time. I’ve upgraded some hardware and run a variety of tests and I still don’t think I’m getting the speeds I should. I’m out of ideas and...
Feb 04, 2012Guru - Experienced User
I prefer timing drop and drag over IOMeter.
It might be useful to experiment with the PC NIC settings while in direct connect. For instance, try turning off any off-loading processing, interrupt moderation, etc.
Make sure rx and tx flow control are turned on.
