mas99
Feb 03, 2012Aspirant
Trouble shooting slow network speeds on NV
I’ve had slow transfer speeds on my internal network for some time. I’ve upgraded some hardware and run a variety of tests and I still don’t think I’m getting the speeds I should. I’m out of ideas and...
mas99
Feb 05, 2012Aspirant
mdgm wrote: So which of these are enabled? What about standard file protocols?
The ones I listed are the ones enabled, if I understand your question. File protocols are CIFS, NFS, HTTP and Rsync for most shares
Also for consistent performance results it's best to reboot between tests.
When you say reboot between tests, do you mean drag and drop or IOMeter or both?
What service are you using to play the videos and how are you doing your backups?
Well, I've had problems with the DLNA, particularly the photo resolution. But since I installed it, I've used a LG BluRay (I can get model # if that is relevant) and Direct TV. BTW, how can I tell which version of ReadyDLNA add on is installed? I think I'm using the most current one, but am not sure.
As for backups, you've helped me on this. I keep 2 sets of backups -- the NAS is a backup for me, and I use Ext3 formatted USB to back up the NAS. After my initial backups, I'm using Rsync, essentially.
