mas99
Feb 03, 2012Aspirant
Trouble shooting slow network speeds on NV
I’ve had slow transfer speeds on my internal network for some time. I’ve upgraded some hardware and run a variety of tests and I still don’t think I’m getting the speeds I should. I’m out of ideas and...
mdgm-ntgr
Feb 05, 2012NETGEAR Employee Retired
mas99 wrote:
Also for consistent performance results it's best to reboot between tests.
When you say reboot between tests, do you mean drag and drop or IOMeter or both?
Both. Well this is for performance testing to see what NAS is capable of. Testing to see how the NAS is running after an extended period of usage is another matter.
mas99 wrote:
BTW, how can I tell which version of ReadyDLNA add on is installed? I think I'm using the most current one, but am not sure.
Under Services > Streaming Services > ReadyDLNA you should see the version number in the bottom right hand corner e.g. 1.0.22
mas99 wrote:
As for backups, you've helped me on this. I keep 2 sets of backups -- the NAS is a backup for me, and I use Ext3 formatted USB to back up the NAS. After my initial backups, I'm using Rsync, essentially.
Right. How do you backup your computer to the NAS?
