RuudB
Sep 20, 2017Aspirant
Trouble with the disk in tray 1
I have a very strange problem. The disc in Tray 1 will no longer connect. I thought the disk was crashing, or at least the boot sector. After some repair attempts (CHKDSK and so on), I concluded that something was wrong with the drive and I returned it to the factory (warranty). Yesterday I received a new disk (Seagate Ironwolf).
Immediately put in tray 1; no reaction.
What is going on.
The disk in Tray 2 is perfect when I install a disc in Tray 1, the system tries to connect that disk without success. As soon as I remove disk 1 from the tray, it will be re-connected to disk 2. When I start the NAS with the 2 discs, it will not start. When I start the NAS with Disk 2 in Tray 1, I get the "root error" error.
I have tried to reinstall the operating system by holding reset button for 5 seconds, no result. I have already tried to reinstall the factory setting, no result with 2 disks in the NAS, as soon as I remove the new disk from Tray 1, the system will only perform the reinstallation for disk 2.
Does anyone have any idea. Thank you
What is going on.
What size is the IronWolf drive? The duo v1 is limited to 2 TB.
- RuudBAspirant
2Tb
Then it sounds like the first bay has failed (esp. if the same disk+tray works in slot 2).
If so, there's nothing that can be done - you'll either need to live w/o RAID or get a new NAS. The RN212 is the currently shipping equivalent to the Duo. It's much faster, handles modern disk sizes, and has a lot more features.
