jamminontoast
Jan 20, 2018Aspirant
troubleshooting: RN316 very slow to view directories of files
To be frank; i've been using the home NAS for quite a few years and its basically a data storage box which backs up my files and media files for streaming. Works well for these sceniarios, however wh...
Jan 21, 2018Guru - Experienced User
What firmware is the NAS running?
Are you trying the directory browsing test over ethernet or over wifi?
jamminontoast
Jan 22, 2018Aspirant
Firmware is 6.9.1 (generally i update to the latest when told)
Browsing the directory is via WIFI...
i have 'invested' in the latest WIFI tech so i would have 'hope' that at least get a decent speed, even if my MBPs (2014) it uses "802.11ac Wi-Fi wireless networking; IEEE 802.11a/b/g/n compatible" - however that browsing directory speed is very poor....
I'd prefer NEVER to cable my apartment.
Tried switching off anti-virus. Don't know if taking on the mamoth task to change from RAID6 to RAID10 will make any substantial difference in this regard...
- StephenBJan 22, 2018Guru - Experienced User
Understood, but doing a test with ethernet is the best way to rule out the wifi network. One big issue (especially in an apartment building) is WiFi interference from your neighbors - who are sharing the same radio spectrum you are using. Also there can be interference from microwave ovens, nearby elevators, etc.
I don't think it will. One thing that will help is using the new SSD metadata tiering feature. That requires at least on free slot in the NAS for the SSD.
- jamminontoastJan 25, 2018Aspirant
Thanks guys: the router is wired to the NAS, however the computers are all wireless. The MBP are generally ~16ft away - clear signal directly without walls or interference.
i followed your suggestions and there are some other thoughts.
1. Using the cable, i get somewhat (random?) responses. Some folders will pull up from 0- 3 seconds. Then i may decide to back out to the root and it takes 10s to open another. i've loaded what my screen looks like here: http://bit.ly/2DDvjNX < apologies for the flickering...
2. Using my User account on MY owned 2x MBPs.... (2013 and latest MBP 2017) - same results.
3. Using a different user on a different MBP (same specs as mine) - they have no problems . Most folders pull up in 0-3 seconds.
4. Using my User account on the OTHER 2x MBPs.... the speed is relatively normal again... even browsing through folders with 100's of sub folders.
This looks to be a 'user' aka. (ME!!) error some where... both MY MBPs have been refreshed earlier with High Sierra along with the other MBPs. So i am baffled at why this is the case...
- 1. the only difference between my workstation and my partner's workstation is probably the amount of software i have on mine. Though most are shut off and spun up when required.
- 2. the other difference is that i have about 8 different share folders whereas i limit my partners to 2. Most of my shares are software documentation folders which runs into the (300GB + and millions of files). However the testing (as per the video) is done against our media drive.
i am competely lost.... ;(
[edit] - i've been reading up on RAID10 recently and should of went with that RAID setup instead of 6.... had done a few resyncs as of late and the speed does suck on transfers... anywhere from 1- 20MB/s transfer depending on size of files.
i will also add to this, i was previously using PATHFINDER software, which also allowed me to see invisible files - it took the mac/ or network extra processing time... though i switch completely to finder and results are not much better (a little bit).
Though my partner's machines, work fine... using the same software is fine! >stumped<
