McGarnagle
Nov 17, 2017Aspirant
TrueCrypt container
Hi I currently store a few TrueCrypt containers on my ReadyNAS 316. I use TryCrypt to mount these containers when i wish to copy/paste additional files into the container. This has always worked f...
- Dec 04, 2017
I have a new local build of the SMB Plus app that adds an option for this setting. Get it from here, and install from the Apps tab, using the Upload button. Then launch the SMB Plus app, go to the Write Options tab, and disable Strict Sync.
We plan to make this a per-share option in a future firmware release.
Sandshark
Nov 18, 2017Sensei
Are you are using dynamic containers, or static ones, and is CoW (Copy on Write, aka BitRot Protection) enabled for the share? I only use static containers and have not run into this, but I can see how it could become a problem on a CoW system to expand a very large file like a dynamic TrueCrypt container. Using static containers reserves all the required space up front, which makes it contiguous and precludes the need for future expansion. But some users do not want to reserve a lot of otherwise unused space. I do, because I use different containers for backing up different PC's and since OS6 still does not have share level quotas (that OS4.x did 10 years ago!!), it's the only way I can use "disk space" as the key to trimming old backups where each machine has it's own specified space available.
If you want to use dynamic containers, you definately want to have CoW disabled on the share.
BTW, TrueCrypt is a bit old in the tooth; you should probably look at VeraCrypt.
McGarnagle
Nov 18, 2017Aspirant
Thanks for the reply.
I use only static containers. In fact i've used the same containers for a long time. Only recently did i start having this issue. I checked CoW also, and the share definitely has is enabled.
I also tried VeryCrypt as suggested. Did a fresh install and created a static 3GB container on the NAS. The same issue occurs. Copy speed starts of about 40 MB/s and immediately begins to drop to below 1MB/s. Extremely frustrating.
- StephenBNov 19, 2017Guru - Experienced User
What firmware are you running? Do you use NIC bonding?
Are snapshots disabled on the shares the container is in?
- McGarnagleNov 19, 2017Aspirant
I'm running firmware 6.9.0, which i do believe i updated not to long ago. Is there a chance that the change from the previous version could be the cause of my issue?
I have no idea what NIC bonding is. However, i can tell you that to my knowledge i havent changed anything since before i started having this issue.
I have snapshots enabled on all my shares. Snapshot Management is set to "Smart" and the Snapthot Schedule is set to "Daily". Additionall, the "Allow Snapshot Access" checkbox is not ticked.
Do you have two ethernet cables connected to the NAS or only one? If you don't know what NIC bonding is, you should only have one cable connected.
Snapshots should be turned off on any shares that hold your TrueCrypt or Veracrypt containers. Otherwise, the container files will become very fragmented over time, and that will hurt their performance.
After you turn off the snapshots in these shares, you should manually delete all the existing snapshots in them. After that, run a balance and then a defrag (using the maintenance functions on the volume settings wheel).
There were some network issues in the 6.9.0 x86 ethernet drivers which should have been fixed automatically (Netgear pushed a hot-fix). If your NAS can reach the internet, then the hot fix should have been picked up by now.
You can confirm this by downloading the NAS log zip bundle, and looking at apt-history.log. Towards the bottom you should see something like
Start-Date: 2017-11-06 04:48:07
Commandline: apt-get -qq install -fy rn-dictionary freeapp-collection readynasos ca-certificates
Upgrade: readynasos:amd64 (6.9.0+2, 6.9.0+4)
End-Date: 2017-11-06 04:48:10The 6.9.0+4 part is the relevant hot fix.
