McGarnagle
Nov 17, 2017Aspirant
TrueCrypt container
Hi I currently store a few TrueCrypt containers on my ReadyNAS 316. I use TryCrypt to mount these containers when i wish to copy/paste additional files into the container. This has always worked f...
- Dec 04, 2017
I have a new local build of the SMB Plus app that adds an option for this setting. Get it from here, and install from the Apps tab, using the Upload button. Then launch the SMB Plus app, go to the Write Options tab, and disable Strict Sync.
We plan to make this a per-share option in a future firmware release.
Nov 19, 2017Guru - Experienced User
What firmware are you running? Do you use NIC bonding?
Are snapshots disabled on the shares the container is in?
McGarnagle
Nov 19, 2017Aspirant
I'm running firmware 6.9.0, which i do believe i updated not to long ago. Is there a chance that the change from the previous version could be the cause of my issue?
I have no idea what NIC bonding is. However, i can tell you that to my knowledge i havent changed anything since before i started having this issue.
I have snapshots enabled on all my shares. Snapshot Management is set to "Smart" and the Snapthot Schedule is set to "Daily". Additionall, the "Allow Snapshot Access" checkbox is not ticked.
