mikedhooer
Jan 20, 2017Tutor
Turn off ssl
is there any way i can turn the ssl off ? I want to buid a website fot my vlog but i dont want that every new user haf to accept the self signd certificate. I have a readynas 102 wit OS 6.6.1 T...
- Jan 21, 2017
Problem solved
I portforwarded my router from Dlink on port 80 but forgot to portforward my router from ISP on port 80
Thx for the help
Jan 20, 2017Guru - Experienced User
If the users are accessing over the internet, you could try only forwarding port 80 (leaving 443 blocked).
- mikedhooerJan 20, 2017Tutor
i cannot connect to my website if i block 443
StephenB wrote:If the users are accessing over the internet, you could try only forwarding port 80 (leaving 443 blocked).
- StephenBJan 20, 2017Guru - Experienced User
Then you have to use https (and ssl). Does your ISP block port 80, or is there another issue?
- mikedhooerJan 21, 2017Tutor
Not that i know of this is the list of ports that got blocked from my ISP
- TCP Poort 25
- TCP/UDP poort 53
- TCP/UDP poort 135
- TCP/UDP poort 137 – 139
- TCP/UDP poort 161 – 162
- TCP poort 445
- TCP poort 1080
Is the not any way that i can acces my site from http and not https ?
